JimKueneman
Well @Billccm I did not follow the "professor of B-Body kueneman" golden rule and I'm paying for it..... OEM or nothing
I do not what it visible under the hood and does Chrysler still make these boxes?Has the professor considered the Chrysler orange box ignition?
Yes mopar performance is still made in the USA. It is oem for 73 to 81 Chrysler cars. My duster and charger used this system and never a failure.I do not what it visible under the hood and does Chrysler still make these boxes?
Orange box has been having some reliability issues over the past few years. If you got an older one, they are awesome. The newer ones I guess are less than stellar on reliability. I also have heard from multiple credible sources that the Chrome box is still made pretty well, but the orange boxes take a crap pretty quickly. Again, this is the newer stuff. I personally had an orange box fail after only a couple years, so I can kinda vouch for the issue myself. Only difference between the boxes is the spark will remain hotter up to a higher RPM and the timing retard feature is not present on the Chrome box as it is in the Orange box. I would get the Chrome box for the extra coin if it were me. Summit was about the cheapest I could find it.
https://www.summitracing.com/parts/dcc-4120534
Why would a feature like timing retard be desirable in the upper RPMs? Also, the chrome box is supposed to be a race unit as it is stated do not run it often under a certain RPM.
I got 3 chormed units gone in 2 years
culprit... transistor.
Replaced one of them with MJ1005 transistor ( the closer to specs I could find locally ) and FIXED the box, just didn't last long maybe due the same quality issues fo the original ones...
got a real NOS MJ10012 pair of transistors and fit one of them. Waiting to find a car to test it ( my car is dissasembled since 4 years ago )
They should last forever if:
Are not over voltage
Are not over current
Are not over heated
They are 400V 20A parts..... If it is not thermal then I would guess a coil that does not have 1.5 ohms and 8mH of inductance or the base drive circuit is crap and keeping the part in the linear range too long.
Hell if I know haha. Maybe that is when **** starts melting!I think maybe they just start falling off with their ability to handle the RPM and output of spark at that level. I do know the Gold unit is the listed race unit. I don't even know where to buy that one anymore. The chrome box has been in my Roadrunner for the 10 years I have owned it and before that with no issues. The description for the Chrome is as follows from Mopar. "These chrome ignition controllers from Mopar Performance will give you a hotter spark and more ignition capability. They're great for general high performance use up through 8,000 rpm."
Talking about them melting, I specifically remember replacing two factory boxes on two seperate cars that oozed the jelly all over the firewall. AND,...in the box of wiring and electrical components I got with my GTX was an orange box that was melted into the wad of engine compartment wiring....what a mess!!!!
Oh, forgot to say... FBO box failed with FBO coil. MP ones failed with MSD Blaster 2 Coil ( an OLD one which is a smalled diameter canister than newers ). Coil is still running ( or it was last time I used my car ) with Rev-N-Nator module strong
