You need to build a cloning machine for a few more Larry's!!!
Are you kidding me . . . there's barely enough room in this world for ONE of me, let alone multiples . . . LMAO
Just be sure that you have an adequate breather tube for the filler pipe .....ask me how I know this.Finally back in the shop and "trying" to make heads and tails out of where I left off . . . but I've got some work done . . .
Trying to figure out this hidden/covered/locking cover for the fuel filler . . . and made some progress . . .
This is how it'll look when the lever is pulled and the door partially pops open . . .
Got the internals figured out, and bolted in place where they need to be . . . had to figure out "how" to do that . . .
On the back side - had to add a pair of brackets that allow the front cover, to hold securely in place, and bolt to the real filler tube
( think this is going to work - now to figure out how to plumb this thing through the floor and to the tank - that I don't have yet . . . )
Had a small area on the passenger rear wheel well that was not "right", and didn't want to fill it with body filler ( that would not hold )
So I added some weld metal, and ground it down to the proper contour so that it'll better hold the body filler . . . ( think this will work better )
Now to try and keep the momentum going . . . need to order my axles ( the rear end was narrowed 3" ) and just a bit nervous to order the new ones . . .
That's about the only fun I can have in my Chevy Cruze
