Haha Wooks, I didn't know you were a comedian too! The longer I can avoid you in the next lane the better, haha.Faster than Barney.
Good Luck Pal.
malex, Pat Blais, the guy that builds my trans and has been doing torqueflites for about 50 years has never R&R the sprag with a bolt in. Never had any problems and my GTX 60 fts. in the low 1.40's with a best of 10.34Oldbee that is Exactly what the plan is over here. Waiting for Doug to check in.
I'd sure like to know what's inside though for upgrades. If there wasn't even a bolt in sprag inside that could be disaster.
---malex, Pat Blais, the guy that builds my trans and has been doing torqueflites for about 50 years has never R&R the sprag with a bolt in. Never had any problems and my GTX 60 fts. in the low 1.40's with a best of 10.34
Bob
----I broke the ring and pinion last september, and yes it took the 'bolt in' sprag out along with cracking the rear drum. I believe the bolt in sprag did save the case as the outer race did not spin and chew up the case. fwiwView attachment 576531
---Dana 60 4.30 gearsView attachment 576544
Measure 5 times, adjust once? Where are you located at for curiosity?Not big power, about 8 years on the gears. My first attempt at setting up the gears, and too much backlash.
Hilliard,OhMeasure 5 times, adjust once? Where are you located at for curiosity?
Having made my first pass at Sacramento Raceway in '72, I have seen a couple grenades in the past that began as a torqueflite. Not mine, but this can result in considerable carnage. I agree replacing the sprag with a bolt-in is done most of the time. Pat, my friend and trans builder has a '63 Plymouth Max Wedge and his daily driver was a '70 Hemi cuda. To answer your question, Yes, I do have a trans brake and leave at 3500. I trust Pat's judgment. Just curious, are you close to Mission Raceway?---
GTX this is very interesting to read. Replacing the sprag with a quality bolt-in type with more rollers is a common upgrade for the 727 race transmission. I haven't personally experienced nor seen a failed sprag but there's plenty of people who talk about it.
I even installed a A&A bolt-in sprag in my "next project" 727 while I had it apart.
GTX do you use a transbrake on your car?
----Having made my first pass at Sacramento Raceway in '72, I have seen a couple grenades in the past that began as a torqueflite. Not mine, but this can result in considerable carnage. I agree replacing the sprag with a bolt-in is done most of the time. Pat, my friend and trans builder has a '63 Plymouth Max Wedge and his daily driver was a '70 Hemi cuda. To answer your question, Yes, I do have a trans brake and leave at 3500. I trust Pat's judgment. Just curious, are you close to Mission Raceway?
Bob
---The "grenade" is when the stock front drum over revs and explodes. Number #1 trans upgrade should be an aftermarket front drum able to handle the 2.2 rev's seen. Even a 12 second car can explode the stock front drum if it over rev's. The bolt in sprag might save the case that's about it.
Thanks malex, you have a very nice car, looks like we run about the same times.
The 16 roller type is the best available. Most of the bolt-ins were designed as case savers when the stock outer race becomes loose. Jeff Freese broke a Dana 2 years ago with his 10.0 N/SS car. I tried to fix it at the track. It had a 16 element. Still took out the case.---
Thanks NSS. Yes the front drum is key, My trany has a new low-gear set, aluminum front drum and 16-roller Ultimate sprag now. Lenny @ Ultimate built me a nice converter too, matched to my car, and the new weight, will be a nice upgrade from the 2nd hand converter I bought from the classifieds and was using. Also changed the front input shaft in the trany, the splines were twisted on the one that came out.
