Getting ready to replace my cowl
Moparstyle
7:08 PM
Nevada
Hey guys any suggestions on what bonding adhesive i should use or should i use any at all thanks before hand for any input
? Bonding adhesive? The cowl is a structural member. Weld it like the factory did.
I would brace it like this then clamp it and make sure you start on the middle and work your way out towards the doors
0E04658D-B36A-4ED9-BABB-D588AF47CFE0.jpeg C0FC7920-2D37-4512-9A16-6D1FC71E9FC1.jpeg 322B5C27-009E-4EC2-B249-A67C78DC41A1.jpeg
Brace the windshield opening as well jump back and forth on the inside of the car to the outside of the car keeping the clamps on either side of the spot weld to keep it tight.This techinique keeps th cowl sitting flat to the flange below.Wash both flanges with Acetone first then spray with weld through primer.
Thats right I asked the guy who restores Mopar’s here and he said to weld though it to.Dont scrimp on the bracing. I learned the more bracing the better the power of welds is Is unbelievable.Good luck I hope this helps.
Thank you very much for the help little bit more fitting and it will be ready to weld in thanks again
Well just about to the point i can start welding as you all know the aftermarket dont fit perfect like Oem plus im picky lol ill post some pics after its finished feels good to see the old girl actually going back together
