Geri
Deceased, But not forgotton
anyone running B-RB engines with Aluminum heads? what brand- and opinion. local machine shop said stay away from import(Chinese) Alum heads as the seats/ guides come loose opinions?
Trick flow and Edelbrock seem to be right up there, Speedmaster sells them but I believe they are made in china that has trouble with valve seats falling out- guides coming loose. never a good idea. I'm always lookng for the right stuff- or very different-thinking of putting 426 hemi heads on the 383 . I'd have to fab an intake but -how hard can that be? thanks for the tips , still just thinking ,gotta plan 2 years down the road. as an FYI I used to run the Accell duel point race distributors that in the70's really worked great. thy have a2 wire lead one for each set of points, the black wire has a plug together in the pigtail,I would unplug that run it to a toggle switch on the gear shifter when shifting to high gear I'd flip that switch which would open the circuit to that lead set of points- now it was running only on the second set of points which were phased 7 degrees opening/closing apart. this retarded the spark 7 degree's, that made a difference of 6-8 mph and 2-3 10th on the ET. I'm sure todays electronic ignition is light years better. but it worked in that era. I still have an NOS Accell distributor which will be on the 383.Edelbrock victor max wedge heads here.
Trick Flow all the way.anyone running B-RB engines with Aluminum heads? what brand- and opinion. local machine shop said stay away from import(Chinese) Alum heads as the seats/ guides come loose opinions?
Every head needs to be gone through, never bolt on ootbTell me why trick flows out of box bolt ons and don't have to do any benchwork need help cause i have to make up my mind which heads to run on my mild 440
never expect race parts to be perfect out of the box,suspect everything and be grateful for the parts are as described- especially headsTell me why trick flows out of box bolt ons and don't have to do any benchwork need help cause i have to make up my mind which heads to run on my mild 440
you can save me a lot of expense if you will send that engine to me, I'll even put your name on the car .
