I got tired of running in the dark with those hids that god had driving lights under the bumper that i could flip down and keep driving. Good luck with the relay later on. Just a note when setting up the relay don't forget about the one way diode so you don't get feed back when on low beams sometimes high beams has a low current that will make come on dim. Just a thought
got my setup going. just need to put back in place
watermelon
View attachment 587918 View attachment 587919 View attachment 587920
Nice upgrade, wish there was a simpler replacement that didn't cost $300-$400
Did you use one of the above schematics?? If not, post what you did. Also, where would one even find these transformers/relays/ballast to build this set up from scratch??
