HELP!!!
pjm8047
5:26 PM
Clay,NY
So I’m trying to reinstall my heavy *** steering gearbox on my back and I cannot get the top mounting bolt to go in all the way stops half way.I’m not sure what is going on. is it stripped? if so am I screwed? Can I use only two bolts?
are the threads jacked up? did you try switching the bolts,is the gearbox tight to the block? Slow down and look at the bolts.Your not screwed.
I tried all three bolts same result the other two mounting holes have no problems.. Trying to start them with the box off. I cant see the threads. At first I got the bottom bolt in with the box in but couldn’t get top one started. I hope I didn’t damage anything.
ok first was the gearbox on the car and you took it off? car year what you have?can you put something in the bolt hole ,in the good ones to measure depth and check it on the one your have the problem with.a pencil would work.
The 833 4 speed uses 4 bolts, not three, right?
(OP edited the first post to clarify he meant the steering box, not"gearbox")
Power steering gearbox im talking about. Bolts came off easy when first took it off.
Looks like a welding on nut on back side and u cant get hands on.
Not a transmission? Well, that is different. Maybe you are frustrated and forgot to make that clear.
The holes for the steering gearbox are just barely larger than the mounting bolts so if the box is not correctly in position, the bolts may not thread in easily.
Maybe you are using the wrong bolts?
SLOW DOWN!!! First, remove the steering box. Now, chase the threads on EVERY hole. After that, check EVERY bolt to ensure that there is no damage, cross threading, marred threads, etc. If you have access, clean the threads with a wire wheel. Try ALL the bolts BEFORE installing the steering box. You CAN NOT install the box missing a bolt!!
buy a tap and clean the threads ,you can buy one at Lowes just bring the bolt with you.
As stated pull box out ! Clean holes bolts chase threads see if bolts go in and out . If they do great that's not your issue ,first ? Did you compare the boxs to make sure the holes are in the correct place? You would be amazed at the crap they will sell you . Start the bolts is bolt still an issue? Make sure other two are loose still move boxes around till 3rd bolt starts there's alot of play if it's just hanging on 2 the 3rd you'll never start only half your hole will be showing.
Maybe unbolt the motor mounts and lift the engine a couple inches?
Going to try a shorter bolt might have enough threads to hold on to gearbox.
