oldbee
Well “back in the day” my frt.end guy put in like +2 caster(?) for drag racing. It was very stable, but, it took arm strength, which I had back then!(manual steer.box). It tracked very good.
What engine did it have? My 66 Belvedere had all the caster I could get in it and it was also stable at high speeds but the car was lightened to 2950 with the factory AC still in it. Granted, it was a /6 with an auto. Can't remember what a /6 weighs but they aren't all that light but think the over all weight of the car made the biggest difference...Well “back in the day” my frt.end guy put in like +2 caster(?) for drag racing. It was very stable, but, it took arm strength, which I had back then!(manual steer.box). It tracked very good.
3600# Bee, auto with a 440. No correcting necessary @ 110-115mph(?) Can’t really remember, although it got pretty squirrelly when a rod let loose & doused the slicks with eng. oil.What engine did it have? My 66 Belvedere had all the caster I could get in it and it was also stable at high speeds but the car was lightened to 2950 with the factory AC still in it. Granted, it was a /6 with an auto. Can't remember what a /6 weighs but they aren't all that light but think the over all weight of the car made the biggest difference...
I have a ‘70 Belvedere. I’ve replaced all upper control arm bushings, tie rods, ball joints, and idler arm but still get the floating play side to side when the car is 60mph and over. I know that’s a “trait” but how can I improve that? Is it all in the original steering gear box?
Yes! Literally not the same car. Money well spent.Sonny, did you get the wandering sorted out? I'm having the same issue with my 68 Charger...
Just the new Borgeson gear box. I think my wandering was just gearbox play.How did you sort out your wandering? I installed Hotchkiss' adjustable upper control arms and am now running 6 degrees of positive caster which is the maximum. Definitely helped stability and handling...
What is your initial impression of the Borgeson box?Just the new Borgeson gear box. I think my wandering was just gearbox play.
Pricey.... but I am enjoying driving the car more. Especially over 65mph. And no more leaks.What is your initial impression of the Borgeson box?
