Parking lights
Ben Bolles
9:06 PM
Branson Missouri
I have just got my 72 satellite up and going and it's started acting up head lights and brake lights work but I have no side markers or running lights and no dash lights any more. They all works when I got the car. I installed an aftermarket oil pressure gauge and when I ran the line something arked underneath the dash and I could have blown a fuse. I'm going to start there when I get home. Any other ideas?
Likely a blown fuse. I was going to say to check your grounds, but losing all those things at once isn't likely to be a ground.
1. Fuses
2. Dash lights
a. 5V voltage limiter behind dash on dash circuit board
b. Dash bulbs
c. Are you gauges still working? (that would rule out 5V limiter)
3. Running lights
a. Headlight switch
b. wiring
I think you might have more than one problem going on.
3.b(b)- grounds, grounds!
You know where the arcing occurred? One thing when checking fuses look at the wiring connections to the block and see if there's any burnt wires or connectors. You should get a bright flashlight and look around for the same under the dash and to the switches, etc. Arcing could have come from an already deteriorated connection when installing your gauge. I had found some wiring in my block that had shifted or was struck by earlier putzing done on the car before I had it. Disconnect your batt before doing the inspection.
One common symptom I've discovered over the years, is the hack job many people have done to underdash wiring. Random cutting, splicing, and yes, loose dangling ends. Do a good, intensive examination of the wiring under there.
It's true. I had an aftermarket tach and a surprise of stereo components in my car when I bought it. On 3 separate occasions, I pulled out 3 bird nests of wire. Literally played out to "Huh, where does this wire go?" Then pull out 9 feet of balled up, open-ended, constant-hot 12 volt wire. Maybe 2 dozen runs of mess, unnecessary parallel connections, and color change splices.
Agreeing again, fuses are quick and easy to check, replace carefully, my old stuff was brittle (don't be afraid of it, but don't get rowdy either).
-If you can stuff yourself into an uncomfortable position, all of your dash bulbs should be daisy chained together with an orange wire behind the cluster. You can follow them like Christmas lights fairly easy. Further up the harness, they can be plugged in parallel in an unsealed multiplex type of connector.
We can give you further details, but if you know where you had caused the problem (wiring your gauge), no sense hunting really deep for now. Report back if you need further help!
Although all the above are good areas to check, I ALWAYS check my grounds first!! Breathe on them wrong and they won’t work!
Ok so I need to go over the grounds but the fuses did not fix any of it the gauges all worked like before but my prioritys on the car have changed because the trans blew today lol.
