- 12:45 PM
- Mar 28, 2014
- South Louisiana
I'm going to order it. They swear the plates fit our Mopar Holley 2 bbls. That will be the first thing I check.
I'm sending my 3 2bbl carbs to Promax soon for the whole kit of parts they offer to be installed and "pre-tuned" on their dyno mule. Outboard carbs get the jetable metering plates, rear carb gets the throttle plate with the angled idle mixture screws so it can be adjusted with the carb installed and running, and the center carb gets their "advanced design" metering block. They will also check the power valve for my idle vacuum reading (11" Hg IIRC) and change that if need be.
It will be then that I install the NX nitrous system. I have and will be posting in the Racers Hangout on the results, but I am posting this here for my 6bbl/6pack brothers.
The NX system:
http://www.nitrousexpress.com/30026-10-holley-2-bbl-tri-power-3-plates-gasoline-50-300hp.html
My posts in the Racers Hangout:
https://www.forbbodiesonly.com/mopa...spacer-plates-will-fit-our-2bbl-carbs.152566/
The NX system:
