changing 8 3/4 centers ?
goo0d new all apart,bad news no adjuster clip and metal chunks.:BangHead: so were do I buy the green bearings Napa?
and is there a specific one I get,I see a couple
different ones. 489 axle summit racing
will I have to remove the thrush block? what the h--- is the thrush block?
If there are metal chunks check your spider gears very closely! Look for any chips or missing pieces
putting a different center in but will check it out.
Oh ok I must have missed that LOL.. make sure you look through the entire housing with a flashlight those chunks tend to go everywhere!
Pictures of metal pieces ? The axle adjuster (picture)
is on right axle near bearing or am I misreading.
There a locking hook to hold it in place.
no locking hook, gone .believe its a part of a gear.
Oh well if you go to green bearings you don't need a thrust spacer or that adjuster...that will come off and be replaced by the flange on the new bearing. (I recently took some axles in to have greens installed, paid $150.. as I'm not equipped nor motivated to do that switch at home)
were did you get you bearings
From the shop that did the labor, I use them for all my major rear end work..they charged me like $80 or so for the parts. Take a look at Dr.Diff's website, he sells them and has lots of good info as well
