727 Trans or Torque Converter Sound
khryslerkid
2:24 PM
Hanover, Pennslyvania
I'll start off saying, I hate these kind of threads and here I am starting one. It's very hard to describe what's going on without being there in person but I'll do the best that I can.
Driving my '62 Polara, 440ci. with the original pushbutton transmission (rebuilt), I'm noticing a harmonic type of sound that's more pronounced in the transmission's location. It's not coming from the rear of the car but in the hump area in the floor.
It puts me in mind to the harmonics that you would get from a fan or a worn bearing or maybe a worn gear. It has a steady cadence like a whirl, whirl, whirl. It is about the same level as the header, dual exhaust note and you really have to pay attention in order to pick up on it.
This takes place at 1800 to 2000 rpm, running between 45 to 50 mph on a level, cruzing road. As this is taking place, I can put it in neutral and it immediately stops. Place it back in drive and it's back.
I have heard that torque converters can do this but there's no other signs of shifting problems or delays placing it in gear, noises ect. The trans was a high milage unit and was rebuilt by a very reputable shop. The only real problem that was found during the rebuild was a worn tailshaft bushing that was replaced.
Let the past experiences with this condition commence!
Is the transmission touching the body anywhere? Lots of transmissions will make some planetary noise but not in 3rd.
It has the normal first gear whine (ever so slightly) but that's gone the moment it shifts to second.
The trans isn't touching anywhere. I am using a Schumacher torque strap but it has rubber isolators on it. Some engine vibration is transferred through it but not like solid mounts.
When you put the car in neutral do you maintain engine RPMs?
Had a hormonic that drove me nuts. Turned out to be an autozone alternator with a smaller pulley than the original used with a mechanical voltage regulator. I changed the drive train twice while on the hunt.
When I place it in neutral the engine rpms increase, then I'd lift just a bit. I can hold it at that rpm anytime in neutral and I'm not having the symptoms.
NO expert on those things,but I’ll go with frt pump. Sure fluid level is Ok?(I’m sure u already checked)
Wish I could help. My 727 has a little whine between 45-50 too..goes away as soon as I lift, or accelerate just a little, and it doesn't always seem to do it...I'm just hoping it hangs in there until I can rebuild it..best of luck to ya
Replaced the wheel, sound still there.
Swapped the driveshaft for another shaft, sound still there.
Check driveshaft angle,(?) sometimes these videos don’t help us at all; i kept thinking u-joint till I saw this is another d-shaft.Kinda sounds like binding(?).
