67 tach wire pic needed
gtxno1
12:16 AM
Freehold N.J.
Hello everyone ready to put my factory tach back in the car did not have it upon purchase I am making up my own wiring and would like it to look as correct as possible can anyone send a pic of the tach wire where it comes through the firewall and goes to the coil thanks 67 gtx
Good information...
http://www.hamtramck-historical.com/_1967AccessoriesCatalog-01.shtml?load_img=28
a 1967 Plymouth GTX that has a factory console tach. or a Vacuumtach… It was a special order from acc…..
Wiring….The green lead goes to the distributor negative side, the orange wire is for the internal light, the black wire is the ground, and the violet wire is the positive voltage supply.
I did some research, never did find location. I used the the plug near the speedo or wiper​
Just need to know if it was like the 68-69 style a 2in pigtail trough the firewall with a connector to the coil lead
My 67 R/T has a hole over on the passenger side under the heater box. Factory tach and wire.
