wsutard
Im in the process of installing an American Powertrain hydraulic clutch. I need help with attaching the heim joint to the stock pedal. The instructions say to try to get it in the stock clutch rod mounting location for the best throw ratio. Problem for me is there are no mounting holes in the stock pedal and my pedal assembly is installed in the car.
Any advice or pics on where to install the heim joint? Should I try to drill out the stock stud? Maybe drill right under that location on the pedal itself?
