Locked Glove Box 65 Satellite
65PlymSatellite
5:07 AM
Inland Empire, CA USA
Anyone have any experience breaking into a locked glove box? I’ve never had the key. Tried going in through the rear hoping that the liner wasn’t there, but it is. Should I just admit defeat and go to a locksmith? Should I rip off that liner and replace it later?
65PS, does'nt the trunk key work like on my 64 ply. Dave
Glove box liner is much cheaper than a locksmith unless you know one personally that will do you a favor. A locksmith will probably have to drill it out anyway judging by the last two that I had to call for various other things on basic locks.
Just another option but I would by a lock pick set off of eBay (Now you will have the set for life), pick the lock which is rather easy and then take all the pins out and re-pin the lock to work with your existing trunk key. It is NOT hard at all and there are plenty of videos on YouTube on how to do it.
I bought a nicer Blue Point set at a pawn shop and was surprised at how easy it was to pick and re-pin the locks on my '69 - Good Luck!
You could try removing the hinge screws under the dash, then see if the door will lift up and pull out at the bottom. Never tried this, just a thought.
Yes, these locks are very easy to pick. Check out YouTube.
That sounds like a good idea, I'm going to try that!
Lock Pick set worked!
6BBE63F0-673E-4200-951B-97F9925DCD53.jpeg 0BCEFD64-68DC-40CA-8564-D2B694458C3D.jpeg
Good for you! Now you also have a new life skill!
Check YouTube for how to open a padlock with a piece of aluminum soda can. You will never trust a padlock with your valuables again.
Great advice! Glad I read this thread. I learned something.....
