- 11:40 AM
- Jan 16, 2011
- NorCal Sierras
In HS way, way back when, 1975/76-ish
my mostly bone stock 68 Charger R/T
4000+#'s 440 4bbl 375hp/727TF
power steering, power brakes, 3.55:1 8-3/4 rear with sure grip,
2-1/4" exhaust, factory exhaust out the back & intake/carb etc.,
IIRC an open element taller Moroso air cleaner/filter
Polyglass GT Bias tires with N50/15 on Cragers
launch at appr. 2000 rpm/foot braking, shifting at 5500 or so
would run high 13.90's @ 103-105
with a little timing added, like 15*-16* initial, different lighter advance springs,
in the distributor, a hotter coil, better plug wires, 1 step cooler spark plugs,
a bit of a different stepped rods (jetting up) in the Carter Carb
& premium pump gas, hot after driving an hour or more to get there...
@ either Sacramento or Fremont Raceway,
Fremont was better air, run a bit quicker,
a couple mph better, a few hundredths better in ET
I rarely ever had anything mostly stock or for an apples to apples comparisons...
I was always messing with something or adding something...
