Aarons Air
I have ceramic coated headers. And stainless tips. I need everything in between. With our cars & the relatively little driving they see, is stainless better/ necessary, or mostly used for looks ?
			Thanks. So stainless is mostly for the coolness factor ?here is a piece of aluminized exhaust that I cut out to install headers to my car this year, this exhaust system is over 12 years old and the car gets driven alot every year. Check out how thicK this pipe is and it is heavy to
View attachment 634575 View attachment 634576
I have ceramic coated headers. And stainless tips. I need everything in between. With our cars & the relatively little driving they see, is stainless better/ necessary, or mostly used for looks ?[/QUO what car do you have?
I don't think country of origin is the difference.
409 is most commonly used in exhaust systems, it is a ferritic stainless, is magnetic and will rust. The choice between 300 verses 400 series stainless is cost/benefit. Northern states that use salt, 300 will hold appearance longer and better. I believe that most of the OEMs are using 409, and some are using aluminized 409.
That said, I'm amazed how well aluminized carbon steel holds up. If you are on a budget, probably aluminized carbon steel.
