Rear disc brake conversion
Doug Larsson
12:25 PM
I've got a 1973 Dodge Charger SE with a 8 1/4 in it is like to convert it to disc brakes I found this company. If any one has suggestions I'm opened to them.
Thank you
I've never heard of them. My suggestion is to talk to Cass at Doctor Diff. He has a good reputation on here, and I bought my front disc conversion parts from him and he was very helpful.
Nothing Jeep or Dakota based that will work? 8 1/4 rears have been around a long time. Mopar Action is actually doing a two-part rear disc article right now, using jeep parts adapted for the 8 3/4.
I'm sort of in Monclaire's corner on this one. If it were my car (which it isn't), I would at least consider finding an 8-3/4" rear end and do the rear disc conversion to it. They were a stock option. I had a 73 Charger 318 auto car that came factory with an 8-3/4". Do you NEED it with a 318/6cyl? No. Would it be a good idea for any future upgrades in performance? Yes.
I went with the SSBC front discs on my 70 Satty 318.They work great. Are you doing front and rears? That looks like a front kit. With a 318, it really doesn't pay to convert the rears also, so the 8 1/4 wouldn't be a factor.
SSBC has been on my 65 from back in 2002. Front and rear manual disc brakes.Work just fine and stops the Hemi with no problem. Did it need discs ? No. Did I want discs ? yes. Would I do it again ? Doubt it. But that's just me.
I haven't even got that far into knowing newer vehicles would adapt to my car thanks for the heads up I'll check it out
I'd like to do both it has disc up front but they need to be rebuilt and I figured why not not go all in and do a complete new set up.
I have and 8 3/4 sitting in the garage just haven't had the time to inspect it get some fab work done to the rear end to fit my car .
Well that is, and isn't, what I am suggesting. The article focuses on adapting Jeep Liberty rear brakes to an 8 3/4. So there is that route. But doesn't the Liberty use an 8 1/4? So it may actually be a bolt-on for the axle that is currently in the car.
Traditionally, I have not been a big rear disc fan but as Eberg says in the article, even the cheapest econoboxes out there have excellent braking these days. I personally would be open to swapping if it's a bolt on deal, but the Liberty rotors are like 12.4", which I am assuming won't clear with a 14" road wheel. That may or may not be a concern for you, IDK. It is for me.
If you have the correct 8-3/4" it's a bolt-in swap. Maybe take another peek at that rear end?
No it's not I have to flip the perches and shortened it a tad it came out of a truck I think plus I'm not sure but the guy said it had a 3:23 open 742 case .Some idiot drilled a hole in the back of the case to drain the oil I gotta have my friend weld up the hole .
I'd like to go to Magnum 500 15" wheels so that might work out. One it comes to my 8 3/4 it takes some money to get it the way I want and right now it's not a priority the 8 1/4 works fine .
If you elect to stay with drum brakes, you can install larger drums typically found in c-bodies, later b bodies, trucks and late 70 SUV'S. You need to use the back plate and all related hardware for the larger brake pads. My issue with disk brakes is the E-brake conversion. You also cannot use 14 inch rims. good luck.
The e-brake on the Mopar Jeep brakes are brake shoes inside the rotor, like about every other HD rear disc setup used today.
I was not implying installing the e-brake was not an option. Per the Mopar Action October article you need to weld an adapter to the end of the stock cable. That's fine if you have a welder and can perform the required weld with out damaging the cable. T
