Doug Larsson
- 11:59 AM
- Apr 18, 2016
I haven't even got that far into knowing newer vehicles would adapt to my car thanks for the heads up I'll check it outNothing Jeep or Dakota based that will work? 8 1/4 rears have been around a long time. Mopar Action is actually doing a two-part rear disc article right now, using jeep parts adapted for the 8 3/4.
I'd like to do both it has disc up front but they need to be rebuilt and I figured why not not go all in and do a complete new set up.I went with the SSBC front discs on my 70 Satty 318.They work great. Are you doing front and rears? That looks like a front kit. With a 318, it really doesn't pay to convert the rears also, so the 8 1/4 wouldn't be a factor.
I have and 8 3/4 sitting in the garage just haven't had the time to inspect it get some fab work done to the rear end to fit my car .I'm sort of in Monclaire's corner on this one. If it were my car (which it isn't), I would at least consider finding an 8-3/4" rear end and do the rear disc conversion to it. They were a stock option. I had a 73 Charger 318 auto car that came factory with an 8-3/4". Do you NEED it with a 318/6cyl? No. Would it be a good idea for any future upgrades in performance? Yes.
If you have the correct 8-3/4" it's a bolt-in swap. Maybe take another peek at that rear end?I have and 8 3/4 sitting in the garage just haven't had the time to inspect it get some fab work done to the rear end to fit my car .
No it's not I have to flip the perches and shortened it a tad it came out of a truck I think plus I'm not sure but the guy said it had a 3:23 open 742 case .Some idiot drilled a hole in the back of the case to drain the oil I gotta have my friend weld up the hole .If you have the correct 8-3/4" it's a bolt-in swap. Maybe take another peek at that rear end?
I'd like to go to Magnum 500 15" wheels so that might work out. One it comes to my 8 3/4 it takes some money to get it the way I want and right now it's not a priority the 8 1/4 works fine .Well that is, and isn't, what I am suggesting. The article focuses on adapting Jeep Liberty rear brakes to an 8 3/4. So there is that route. But doesn't the Liberty use an 8 1/4? So it may actually be a bolt-on for the axle that is currently in the car.
Traditionally, I have not been a big rear disc fan but as Eberg says in the article, even the cheapest econoboxes out there have excellent braking these days. I personally would be open to swapping if it's a bolt on deal, but the Liberty rotors are like 12.4", which I am assuming won't clear with a 14" road wheel. That may or may not be a concern for you, IDK. It is for me.
The e-brake on the Mopar Jeep brakes are brake shoes inside the rotor, like about every other HD rear disc setup used today.
