HEATER HOSE ORIENTATION
Bill Monk
12:17 PM
West Virginia
I've looked through past posts and I'm getting conflicting info, on a 69 big block (roadrunner) I believe the hose closest to the block is the core inlet hose and goes to the outer nipple or the one closest to the fender, simple question, is that right?
I'm asking because I'm going to flush the radiator and want to make sure I tap into the right one and make sure they are right in the first place.
From my 69 charger. Does this help? Yes wiring is a mess from previous owner.
The Charger above is incorrect also but it doesn't make any difference on how it works
Well thanks guys but if I understand it right, they are wrong but not sure about that
Gotcha, I just want to make sure I tap into the right hose when I flush it, my understanding was as I said, closest to the block (or intake) is the inlet and goes to the outer most nipple on the core
You need to reverse flush anyway....so it doesn't matter which way around.
