Valve seal question
Sonny
3:20 PM
Florida
Putting my heads back together. Will be at least 4 months or so before I fire this thing up. Do I use oil or assembly lube in the valve guides? If lube, any recommendations?
I would recommend assembly lube. I am using Sta-Lube by CRC with Moly-Graphite.
HERE LUBE NOT PASTE
damn caps lock
paste on the cam lobes and lifters, liquid on the bearings, timing chain etc
Can somebody tell me what this is for? Came with the valve seals.
View attachment 654275 Can somebody tell me what this is for? Came with the valve seals.
Slide that over the valve stem, then slide the seal over that, then remove. Keeps the seal from getting cut by the sharp valve stem tip.
I made my own.
I also cut a piece of 1/2 plastic pipe to tap the positive seals on if you're useing this type.
In my "Photo Garage" I have some pics and tips doing my heads.
