- 2:31 PM
- Mar 28, 2014
- South Louisiana
I started this as a new thread to bring attention to a problem. A new problem.
Changed out stock fuel pump to a Carter M6903. Changed upper and lower fuel lines to Promax braided stainless steel lines w/pressure gauge. Asked for a WIX 3/8ths fuel filter to match my V-code/Hemi factory 3/8ths fuel lines and was happy to find the fuel filter that was on the car when I bought it 4 years ago was the same one I just sourced and installed. No fuel leaks. Carb to intake gaskets provided by Promax are nice, seem to have a slick-ish surface so as not to stick, but they are thinner than the fibre composite ones that were on it. Eliminated vapor separator and plugged the return line.
Carb intake surface is clean and smooth. Fuel is from a nearby station I have always used, 93 octane no ethanol.
So that brings me to the new problem.
As I drive, part throttle, the engine is "pulsing" and "surging" more than it ever has, which was something I had to try to make it do in the past. It always has had a little "surge" or "uneven" climb through the RPM range at part throttle only in the upmost 2k to upper 3k range, but now driving it "normally" it is much more noticeable.
WOT seems fine, idle is great. I checked the 6 idle screw settings with a timing light tach and vacuum gauge, and it is around 14 inches which is as good or better than ever, and really didn't need any idle screw adjustments to speak of. No strong fuel (rich) smell, but you can tell the engine runs on gasoline.
I am about to drive hundreds of miles along the coast for the next week and I would really like to smooth this out.
Timing checks out fine too.
Engine specs in my signature.
Thanks for any
advice!
Thanks for any
