- 12:59 PM
- Jul 31, 2011
- Western Colorado High Desert
No vent box holeAs I stated before, check up under the drivers side of the lower cowl to see if the vent box hole as been patched. That would tell you.
Hole for ac lines coming thru fire wall is oval and both lines enter thru the one oval hole.Holes on AC firewall to the evaporator and heater cores are originally kinda oval for each one of the cores ( one to each one ) while on your firewall are like 4 round holes cut and paired/linked. Aside that, the holes are sealed with somekind of sealer while original pieces are somehow of foamy gaskets
On outer side of firewall is visible the hole to the blower cooling hose used on Heater cars which is sealed with somekind of sealer ( same used on AC and Heater lines inlets ). On Heater cars that cooling hose fits diagonally between blower and that hole. Blower motor is indexed around 120 degrees off to meet the cooling provision coming out from heater box and the mentioned motor hole. For a while AC cars got the blower with the cooling air provision for the motor itself pointing out straight to the floor and firewall is set for that hose. This hose is way smaller.
On both setups this cooling air to refresh the motor comes from fiberglass box. The same air the blower blows out, it gets to the motor to keep it cooler as posible while spinning. The AC/Heater blower is the mothesucker of all the electrical devices on our cars and gets lot of heat due the load required.
Well then if there is no sign that a hole was there then it must be a factory a/c car.No vent box hole
My 73 is a factory A/C car and the inlet/outlet hose nipples do not look like that at all. the simply come through the firewall with no visible mounting brackets.
No vent box hole
Thanks I see those holes now.I found a pic of mine before the engine install. You can see what he means about the oval holes. One drain below the heater motor and another more toward the right (center)
I'd be curious to see if the vent to the left of the dash looks like it's had the hole cut with a saw.
Should be relatively easy to remove the plastic vent.
Also the blower motor fits into a rounded-triangular hole that has a lip around it.
it would be really hard to reproduce that lip.
hard to see in the pic since there's so much goop.
Was there foam in those hose and line pass through hols before the goop was put on?
That foam is nearly indestructible, even here in humid FL.
