How did you get that picture?
Trunk monkee drivin??
dMr. Shorthorse,Mike, I know with your experience you'll find a way.
Still just as a personal observation, it seems that we are all addicted to the idea of just going a bit faster. It's in our blood. But a step back would suggest that as bracket or index racers all we need to do is hit a number regardless of what that number is to be a winner. What comes to mind is a couple of guys I've raced with for years. They basically have 12 second cars they have stuck with throughout the entire time and they are both deadly. I try to remember that with my car but it never works, I just want to go faster.
Doug, I have had long conversation with Cal Trac Tech guys and my shocks are set to the best specs they can offer. They are they Cal Trac 9 way Adjustable shocks.It doesn't cost a dime to turn the knobs on the shocks.
Cal Trac Techs tell me the "preload" on the bars is primarily only to make sure the car goes straight, not veering to left or right...if it veers left or right then the bar pre-load is used to make it go straight. Nothing to do with actual traction.Can I assume you have already found the timing sweet spot and jetted for MPH?
I have not played with the shocks or preload as I have been chasing the SV1 carbs and going nuts with AFR recordings.
I wonder if increasing the preload on the cal-tracs help the 60.......
My next time out will bring me my 1st 8 second slip with my street driven heap! 8.50 is my limit and believe 10-12 lbs of boost will do it.![]()
Yes to timing and jetting.....37 degrees timing and 93/93 on my 1050 Dominator. This gives me the best ET (10.158) and the highest MPH (131.54)...which I am ok with.Can I assume you have already found the timing sweet spot and jetted for MPH?
I could have swore you showed a photo1) I have NO throttle stop.
