Paul_G
- 9:23 PM
- Dec 24, 2013
- Surprise, Arizona
What would be the correct radiator for a 73, 400 engine, with A/C?
The 73 Charger I am rescuing has a 68 383 in it right now. The water pump housing on the 383 has the inlet (lower hose) on the passenger side, and the outlet (upper hose) on the driver side, just like a small block. This radiator is a 26" core, same rad thats in my 72 small block. This radiator is not wide enough to mount in the core support on the 73, about a few inches too narrow. There is a plate mounted to the core support on one side, with the radiator mounted to this plate on that side.
What would be the correct radiator size for this car? It has to be bigger/wider than the 26" thats in it now. I thought 26" was the biggest?
