biomedtechguy
Accelerati Rapidus Maximus
- 1:28 AM
- Mar 28, 2014
- South Louisiana
I have an article from 2016 in Mopar Action magazine (thanks to a forum member who was "housecleaning")
The cover car is a 74 'Cuda, originally equipped with a 360.
That was replaced with a 512 stroker RB motor built by David Vaseleniuck (RIP).
I spoke with a member of the "team" who not only informed me that David V. had passed away, but the guy I spoke with was involved with/familiar with the build.
This is the part that really, REALLY excited me and led to my calling them: 650 horsepower and 720 ft lbs of torque-topped off with what MUST top off my future build on my real V-code 70 Roadrunner, a 6 bbl !
Now I've seen some great 6bbl stroker builds by Jim LaRoy, but I've never seen one with those strong numbers of both HP and TQ. My conversations with builders and others about my goals were always along the lines of "as close to 600 horsepower as possible, but well into the mid to upper 6XX range for torque". Well this particular engine in this article is beyond what I was thinking could be done, yet there it is. The only details I can get from the article are 512 "full roller" (I'm not 100% sure what that means, but I guess roller cam/lifters, rockers, timing chain?) 11.5:1 CR Eagle internals, six pack intake. There is a 200 HP shot nitrous system on it but the owner said he has never used it because the output of the engine is "scary" as is. (much less adding another 200 HP kick) My concern about hitting the button at that level of power would be breaking a great motor (there's no indication that the block is anything other than Chrysler factory)
So the guy I spoke with is named Bill Ross, and all I can say is I hope they can get as close as possible to duplicating those output numbers for me. Their location in North Carolina is close enough to south Louisiana where if they were OK with it, I would drive up the last couple of days of the build so I could check out the final assembly and dyno work, and drive that sweet mill home!
I would need surgery to get the GRIN off my face!
Anyone know Bill Ross or David Vaseleniuck or any of their Mopar engine work? (they do other brands as well)
The car's owner's name is Bryon Webber and the car is a 74 ' Cuda. A pic in the article shows a "Power Tour 2014" sticker across the top of the windshield, so I'm taking from that and other parts of the story that this is a very reliable ride as well.
If I go this route, I will certainly follow up.
Thanks in advance for any info if any of you know this car or this shop or their work.
 Jim LaRoy, but I've never seen one with those strong numbers of both HP and TQ. My conversations with builders and others about my goals were always along the lines of "as close to 600 horsepower as possible, but well into the mid to upper 6XX range for torque". Well this particular engine in this article is beyond what I was thinking could be done, yet there it is. The only details I can get from the article are 512 "full roller" (I'm not 100% sure what that means, but I guess roller cam/lifters, rockers, timing chain?) 11.5:1 CR Eagle internals, six pack intake. There is a 200 HP shot nitrous system on it but the owner said he has never used it because the output of the engine is "scary" as is. (much less adding another 200 HP kick) My concern about hitting the button at that level of power would be breaking a great motor (there's no indication that the block is anything other than Chrysler factory)So the guy I spoke with is named Bill Ross, and all I can say is I hope they can get as close as possible to duplicating those output numbers for me. Their location in North Carolina is close enough to south Louisiana where if they were OK with it, I would drive up the last couple of days of the build so I could check out the final assembly and dyno work, and drive that sweet mill home!
