pdiz
Just for the record, '75-later B-body stabilizer links such as the Rare Parts RP18110 or the NAPA 265-1931 are not quite the same as for '73-'74 B-Bodies as the stem is just a tad too long. Nowhere did anyone say it would, but the part looked the same so I decided to take a chance. That being said, I presume I can't run the longer ones because my suspension will be out of whack and not line up? Anyone know where I can find the correct ones? I have a bent stem on one side and I guess I can just try to straighten it with a torch and a vice? Running all rubber MOOG parts on mine and they don't have the actual arm, just the bushings/washers/spacers/nuts. See attached photo; OEM on the left, '75-later B-Body on the right.
