Buying the correct torque converter
JamesF
11:06 PM
Tupelo
I ordered a 10417 torque converter from B&M thinking it was the right size but the hole pattern is different than the one I took off of the car. Date on 727 and 383 is 1970.
Try these guys...
https://revmaxconverters.com/
I used them, gave them the specs I had and hand built and shipped quickly. It was reasonable too and fit was great and even better works well with the setup!
Call John Cope @CRT and give him your specs. He uses PTC and builds to suit. I have two, and will use him in the future as well.
Ya you can use cope or a&a trans. Or just go directly to PTC
There are 2 different factory converter bolt patterns. Buy a B&M or aftermarket flex plate. Or if you know a good machinist have them redrill it.
Thank you
redrill to make it look like this one.
The 10417 is an 11", same as the 383HP would have come with. If it wasn't originally a HP it would have come with a 12" converter with a different flex plate.
The 10417 is a 10" I think but I need 11 1/8 bolt pattern.
As you can see from the B&M picture, there are 2 different bolt circle diameters AND the larger size bolt holes for the Hemi (or some aftermarket) 7/16 bolts. The B&M plate pictured covers them all. Beware of the 1 offset lug too & which side of the plate goes toward the block.
Got mine from 440 Source, Not SFI and the only real difference is the $10 sticker as far as I can see.
