Picked up a 440 dual point distributor that has a bit of slop in the upper bushing but is otherwise nice. Not having much luck surfing around and finding bushing replacement kits. Anyone know of a good source?
The mopar nos ones for the dual points are seriously getting pricey now.
Right. Harder(maybe) to find is the right reamer to use on the bushing, once it's installed.
When I replaced 'em, I used a 'piloted' adjustable reamer. Pilot end reaches the opposite bushing, to keep both bushings in line. Going to guess their still around.
Liked millers piloted reamer. Grainger bushings and adjustable reamer.
View attachment 746562 View attachment 746563 View attachment 746562 View attachment 746563
Wouldn't hurt to ask for Oilite bushings, true @62MAX.You have to be careful,not all bushings are oil impregnated porous bronze.
Is the reamer considered superior to the burnishing tool that expands the bushing to size?
What's the correct length - 5/8" or 1"? I suspect 5/8". If no one is sure I'll take it apart and measure them.
That 5/8" length it does sound short. Will try to measure one tomorrow, have couple empty housings.The few I have left are 1 1/8"
Have looked at many steel shafts, run on straight bronze bushings...wears the steel out!Burnishing tool would mostly be good, only for bushing already sized correctly, ID/OD, so once in place, ID is sized by 'seating' the bushing. Yeah, OEM bushing like that...and the price!Is the reamer considered superior to the burnishing tool that expands the bushing to size?
That sounds about right. I will break out a set and measure them completely today.The few I have left are 1 1/8"
