What a stupid thing I did!
I'm an idiot so don't listen to me.
I would try to flush the **** out of it first (air pressurized water)then button it up and run that ******.
I've seen these old V8s eat some **** that didn't even make them burp. Those are some pretty small pieces you're talking about. If a pressurized flush won't puke it out, normal running probably won't move it. Chances are you got it with the vac but can't find it.
I agree RUN THE ******!!:rofl:
My word guys, we're talking about a tiny Dremel wire brush.. it ain't going to cut off flow or cause mass destruction for crying out loud!:rolleyes: I just rebuilt a 318 that had enough mud and dirt in it to build a mud hut and it was still running strong. I say try the frost plug, if no luck then just run it.
Next time use a tap instead.:thumbsup:
Yea but one could pour concrete down the intake of a 318 and it may make it smoke a bit.
One of the best Ma ever designed.
I agree.....
Run the piss out of it.........
I also can’t believe this is 3 pages, lol
It should fit. The magnet OD is smaller than the hole ID.
9/16" hole=.563 inch
10 mm magnet od= .394 inch
I can't see the brush with my camera so I think its in the water jacket, the magnet would not help at this point. That it a good idea to get that though.
Guys...
If the pump can withstand leftover chunks of the sand cores going through it, not to mention rust scale turned to mud, a tiny wire brush isn't a big deal.
I certainly hope so, I'm not ready to start it yet because I have to put the new starter in, but when I do I will be listening closely to see if I can hear anything.
Well if the block gets a hole in the water jacket and the coolant gets into the oil pan the little brush could get sucked into the oil pump and really screw things up!!!!
I think the wire brush is the least of your worries at that point :lol:
Pulling freeze plugs on that side of engine and flushing? Just a thought.....
I'm going to pull the upper radiator hose and flush, that way the brush has no way of going any further to the water pump.
I know a few idiots, your not one. Actually a very smart guy.
New guy chiming in. Not an expert but am an ASE Master Tech and a shop owner.
I wouldn't give that brush in that hole five seconds of thought. Send it!
It is not a 9/16 in hole. It is a 3/8 hole. The bolt head in 9/16. If you can't snatch it out with a pick, don't worry about it.
Thanks Steve. Why the hell did you give me the big red X above then? :rofl:
Send it indeed! Then run that ******.
