- 3:52 PM
- Jun 12, 2012
- NZ - just short of the South Pole
Good stuff tackling a transmission like you have Ghost....like the method.
Thanks mate. You know, I have to confess that I have always thought they were way to complex to be messing with. But, Tom Hand assured me that I could do it and has stuck by me with e-mails for questions and problems. His manual is spot on and has a lot of step by step pics and individual sections for every step. hard to go wrong. We shall see later on if the thing actually works in the end! Haha.Good stuff tackling a transmission like you have Ghost....like the method.
In the morning, too lazy to get out of chair...lol.You know the drill, pics!
So now I have the shape all roughed out, holes drilled, installed a plastic guide and added 3" to the bottom because it was too low in the console. On to the wood handle part where I'll make a blank that's slightly larger and bolt it to the handle then grind it down to almost and then finish sand to final shape.
View attachment 755746 View attachment 755747 View attachment 755748 View attachment 755749
I have a stepped plate that will stick up through the white plastic and the metal plate under it, to the left side of the lever. I rigged up a spring loaded cable pull with a drop in tip that will rest in the reverse lock trough. Will have to pull up on the cable to lift the tip out of the lock space and then the rest are rounded humps for the tip to fall into for each gear. I'll hook up a micro pressure switch under that lock space to close the circuit for back up lights. I just have not cut the slot for the plate to come up through yet. I want to install the torque shaft first to see where it sets in relation to the lever. That will assist me in figuring out the length and shape of the linkage arms. I also need to weld on the tab to the lower right side of the lever so the shift linkage that goes up the upper torque shaft arm will hook in.How do you planned to engage park/reverse lockout?
Thanks for your interest! Anytime your re-engineering a factory assembly to fit a custom set up there are many steps involved. Just think of all of those boring R&D meetings I'm missing that the original engineers had to sit through!!How do you planned to engage park/reverse lockout?
