Anyone installed Spectra fuel tank naked / unpainted?
barbiebandit
12:26 AM
ottawa
I posted this in another loosely-related thread but deserves it's own post.
The question: Has anyone had a Spectra fuel tank that they left naked/unpainted and has been installed for over 3 years? If yes... what is the result? Was it a fair-weather only application?
Could always clearcoat it if your looking for that look. Usually undercoat mine but everything’s a driver. Hopefully I helped.
Thanks, what I'm really interested in is whether someone left a Spectra tank naked, because they make the tank with a special Nickel electroplate type coating. In my original post on the other thread I go into stupid detail on it but wanted to keep this post simpler.
I had mine powdercoated...big mistake. The vent lines inside the tank are soldered, which melts below the powdercoating bake temperature.
Same tank as Quanta sells? If so, mines been naked for 6 or so years and still looks new. Installed it in the fairgrounds parking lot of Carlisle after a ratchet strap puncture incident (long story) right before the show. Had to walk in and buy a new sending unit, straps, etc...and installed in on our backs. Still looks great to this day, but it does stay in a heated building and is driven quite frequently all spring, summer, and fall.
Sorry I don't know Quantum. Are they a reseller or a manufacturer of aftermarket parts? The tank I'm asking about is made by Spectra from Ni-terne steel. All their tanks are it seems to me. I'm wondering about their "natural" corrosion resistance.
https://www.spectrapremium.com/en/aftermarket/north-america/fuel-tank
Or if Quantum is actually a tank manufacturer whose tanks are made of Ni-Terne that would be interesting!
Woah... good to know! Thanks for the warning.
The corrosion resistance would be important on the inside of the tank. The outside is cosmetic and corrosion can be controlled by painting. I personally wouldn't trust it not to rust on the outside, even if its around the seams or around the straps where other metals are touching.
I installed my tank 6 years ago, and she is a garage kept car that is only driven in good weather, and never washed with a hose, only hand washed, so the car has not been exposed to much water. The tank looks the same as the day it was installed. I did clear coat the fuel neck and the tank straps only because the plating had come off and that was done as a rust prevention measure.
Two things I never do naked - work on a fuel system and fry bacon.
I do bacon that way because it forces me to slow - cook it on level 6-7 heat so it won't splatter, resulting in the perfect level of controlled crispyness. My chef friend said it was a secret of the best fry cooks
That’s some sensitive temperature sensors you’re using there.
I've done some kinky things naked but never installed a gas tank that way. :carrot:
Well, sure! I figured everyone did? Hell, how else you gonna hold the thing up by yourself while getting the j-bolts started? :)
#invertedpogostick
Quanta says there tank is made of that type of steel so it’s definitely a possibility that they resell that tank...not sure.
Spectra tank on mine, a little over 2 years on the car but driven year round, (no rain or snow) tank still looks fine...
Not sure what brand mine is, but it's Canadian.
It's been in about 3-4 years.
There is some staining but no rusting.
if it's Canadian it's likely a Spectra.
So some staining happening... like mild surface rust or like dulling of the shine in areas?
Thanks!
I think it's a reaction to gas.
Kind of a faint translucent greenish in streaks front to back or vice versa.
