matthon
So, I bought a new floor pan, for obvious reasons, and under the riveted in galvanized signs and a non-existent floor is this.
I want to pull the engine/trans and finish removing the floor, and I need to fix or replace the crossmember.
What's keeping the torsion bar from exiting, or the trans from leaving the scene?
If I completely replace the crossmember, where does it need to be braced to keep it together?
Or, are the front rails, to rockers, to rear rails enough structure to remove the engine, then torsion bars, then crossmember?
