New 440 build oil pressure
My old Chilton manual shows 55psi@2050rpm.
(The “2050” rpm seems kinda odd to me. Perhaps it’s a typo and should be 2500?)
The only reason we’re discussing any of this is because someone wasn’t in love with what they were seeing on the oil pressure gauge.
VR-1 20/50 2/3rds of the year in South Louisiana, VR-1 10/40 when it's cold for about 12 weeks here...That is what I use in my stock block 440, and I used to use in the 4 bolt main 421 Tripower, BUT
Since the 421 has been rebuilt and has roller lifters, now I am using 10/30 Valvoline in the 421 and it is doing great.
I want my next build (stroker RB) to be able to use a 10/30 if possible, all other things equal, thinner oil means more power to the wheels.
No harm. But if it was mine, I would put some effort into understanding why. I would start with double verifying the correctness and accuracy of your gauge, then, 2) pull the current relief valve, or entire pump and verify that the valve is not hung-up and is operating smoothly. 3) contact the builder and get the bearing clearances.
Do you know if it has a new Melling pump, or the factory original pump? Do you know what the oil pressure use to be? If you have the previous pump, maybe try that one.
Yes my thought is the gauge accurate?
IMO, Maybe find out what shimming the pump relief spring stiffer may yield for you. Doesn't cost much. If it shows positive results, get the spring per PRHeads.
After that, I think I might pull the pump and do some tolerance checking.
@Sonny - Any updates on your oil pressure? Curious what you did and what the result was.
I installed a high pressure Melling pump and use 40w oil. Idle pressure is about 12-15 psi and cold is close to 80. Think it created a leak or two at the timing chain cover and or oil pan. Ugh.
Thx! I was thinking about installing a spring to my original pump. I’m is the same boat with regards to ‘low’ pressure. Is the Melling high pressure or volume or stock?
So basically, nothing changed at hot idle due to the pump change.
It helped a little. Doesn’t drop below 10-12. Before it would dip to 8 then recover.
2 psi is not really a change. Plus it sounds like you're using different oil. As mentioned before, the better bandaide for your problem would have been a standard pressure high volume pump
Don’t you need a high volume pan with a high volume pump?
High pressure.
Throw some 20w50 in it and see what change that makes. It should let ya sleep better at night and if the pressure doesn’t go up, you know there’s issues elsewhere.
I saw more improvement going from 30w to 40w than I did from the pump change.
What’s the idle rpm?
1100 park. 800 in gear.
It’s 90 here today and I paid closer attention to the gauge. It never got less than 15 psi in gear in traffic.
My 383/432 Stroker - New motor
180 degrees hot idle 650/700 Rpms
Full groove main bearings - .002 / .0024 Clearance mains/rods
10w30 Valvoline VR1 Idle 18-20 psi - Cruise 70 psi
20w50 Valvoline VR1 Idle 25 psi - Cruise 75 psi
20w50 and forget about it. I ran that summer and winter when I was a kid...
