Thank youA possibility might be t o contact Kevin from www.sykedecutuning.com he is a tuner and knows how to program the ecu. However I don't know if he knows how to program the ecu for the transmission...
I’ll ask
p with a guy named Russel Drake with German automotive and he has Cracked the 8 speed code, and will sell a stand alone system for the 8 speed for $1,000.Have you made any more progress on the 8 speed. would you have to run a trans adaptor to run a 904 behind your 5.7? I think the bellhousing is different, right?
That is awesome.Yes, I actually hooked u
special thanks to Darius for hooking me up with him.
While I’m not ready for his part right now, he is looking for a few people to test his product...
That has motivated me to rock on and get this project done!!!!
keep everyone posted.. as an FYI, I bought the engine and trans out of a wrecked 2016 Dodge Challenger RT with only 7000 miles...5.7hemi with the 8 speed connected to it.. I also have the original shifter which I’ll need to use, which I need to figure out where I’m going to put that....with a bench seat, I may customize a 4 speed hurst handle to work, but I’ll see....the original shifter has the +/- button for shifting on the fly... not necessary but cool....That is awesome.
Are there any updates on this? I have a line on a 392/8Speed and have talked at length with Russell, and have the electronics and fuel system figured out. I Just want to know how much sheet metal surgery is going to be required to fit the 8 speed under the car
Uhhh...I thought this thread was about using the new drivetrain in a classic car.Any updates, I’m looking to to purchase a Hellcat, with or without trans. Thank you.
I guess I need to be more specific, Hellcat engine in a 68 Charger, with a 8 speed trans. And what the issue with it were. Why he didn’t go with the 8 speed and went with the manual 6.Uhhh...I thought this thread was about using the new drivetrain in a classic car.
I didn't know you have a 3rd gen in your car Ulli.My 5.7 was a test mule and done in 2006. It was a very difficult job for it's time. There are a few queer corks my car still has because of having to work around issues there were no answers for at the time. Computer issues were done by one failure at a time. To start my car the key has to be put in the start position for 10 seconds before starting, if you don't, the car will start and never accelerate above about 20 mph no matter how much gas pedal you throw at it. I pull over, turn it off, turn the key to on, listen to the clicking of the computer and fuel pump priming, then start it again and it's perfect. I didn't build my car and the builder spent alot of time and money to make it work. At the time there was no floor shifters available for a 5 speed truck automatic. Mine is set up for, park,reverse, neutral and drive only as far a manually shifting. American shifters now make one. Lewis and Clark didn't have it easy, but those that followed did. No help, just some insight.
