Hi fellas,
The vent itself is leaking gear oil right out the cap and of course all over the housing, shock, and fuel tank.
I have had it out twice and Teflon taped the threads (seems OK), and cut small plugs out of porous foam to insert in the bolt bore-with no luck.
Lube level is below the fill plug.
741 case.
The bolt will hold a vacuum when a vacuum is applied to the bore.
I have never seen this condition before-any thoughts?
741 case.
