daytona kid
I'm trying to put my drive shaft in and keep running into problems. All I have left to figure out is how to secure the straps that hold the rear u joint (7260/7290= napa#347) to the rear end yoke. Do I need some u bolt type retainers? The holes in the yoke do not appear to be threaded, but they seem kinda small fo a u type. Has someone drilled the threads out for me? I bought this chunk used and recently noticed it has a problem. The yoke is stuck, I tried to impact the nut off without success. You can see where some idiot beat on it with a hammer trying to get it loose. So if I can't come up with something to hold the straps on or put u bolts in I'm screwed. Anyone put bolts all the way thru with nuts on the back? Any schooling is appreciated.
