IMHO, I’d be making sure the housing is flat,flat. OE housing & thermostat housing and never a leak with a normal gasket & regular gasket sealer on both sides. Maybe I’m lucky?
Glad to hear all is going well so far. I’ve had mine on for 2 yrs and no problems yet.Follow up...
Member @Cranky came to the rescue and gave up one of his OE housings to a worthy cause
@texas69bee I tried the Permatex for water pumps and t-stat housings.
You can see that I had used the Fel-Pro gasket. The cast aluminium, chrome housing had warped .030
Following the directions, it reminded me of the black gasket maker that I used on my aluminium valve covers. Apply sealant, install finger tight, let it set up for an hour then torque to specs. Let it cure for 24 hrs. before allowing fluid contact.
View attachment 812050 View attachment 812051
Went to a show today, all's well so far
Wow, it's gone up from $27 to $39.95 in under 3 years! I'll have to check back in 3 more years and see the price.Looks like you have this solved but the 440 source one looks an awful lot like the Mancini one and can be had for $27.
http://store.440source.com/Billet-Aluminum-Water-Neck-New/productinfo/114-1004/
Almost 3 years later and still 39.95Wow, it's gone up from $27 to $39.95 in under 3 years! I'll have to check back in 3 more years and see the price.
