440 engine stand mounting
1968340S
4:04 AM
Rescue, California
Just want to be sure that I have the proper mounting for the engine stand.
Using the top two 3/8" threaded with grade 8 bolts and the two lower 7/16"
non thread with grade 8 bolts and nuts.
My concern is the lower driver side mount ( starter) strong enough as the block
has the cast cut out for the starter. Don't want to bust the block.
The only other option is to use the other 3/8" threaded. Looks much more stable
using the lower. Sent pix.
Any advise?
I think the hole around the starter is strong enough, absolutely the most stable. But after looking at your picture, you need to get the tube of the stand up higher on the engine. If you plan on tearing it down and assembling it on the stand you need to center the weight better. On my stand, it was even harder to get the arms spread out while balancing the engine weight.
And them suckers are heavy! Don't use a El cheapo stand. Removing intake and heads before mounting it on the stand can help.
Look around to see if you can find one of these Mopar big block engine stands. The block will bolt right to the stand so you don't have to mess with the four arms.
Cheap stand and my 383 bolted on. Loaded in my truck box and driven 30 miles on bumpy roads over to my paint man and then back.. not an issue!
beerestoration2015-2016 1493.JPG beerestoration2015-2016 1494.JPG dec16c.jpg beerestoration2015-2016 2411.JPG
The bottom two and two on the top has always worked for me. For the bottom hole on the passenger side I use a bigger bolt with a nut and big washer. Don't overthink it, it just needs to be firmly attached..
Judging by the straps you seemed more concerned about losing the stand than losing the engine !!
The original posters method is fine. Same way I do my Mega block which is way heavier than a stock block. Never an issue. Just make sure the rest of the stand is a quality piece.
Wow.. Winternet has set in! I suspect all you guys rent a box truck to move your engines, in case you forget how to drive.
Bolt a 3"larger height and width 1/2" thick plate on that face 1/2" or 9/16"<better, counter sunk bolts. Counter sunk bolts make face smooth. Now drill 4 new holes for your mounting arms so the cam plug can centered.
I use a transport stand.
About 30 bucks at summit or you can fab one up in an afternoon with some angle.
