70 rr windshield &back glass gaskets best?
Beep!Beep!
12:14 AM
Levels wv
finally have a painter , will be needing to install glass soon what brand and where should i buy seals from ?
70 RR, doesn't have a gasket on the rear glass. You need a tape kit, I forgot what thickness.
An auto glass installation company, or glass supply house. There should be some local to you. Measure the thickness of the glass. Measure the depth of the channel. Then subtract the thickness of the glass from it. That will give you thickness of the sealant tape. I would make it slightly thinner so that the molding sits right. I wouldn't use the urethane that they install windshields with now days, but it can be done by a good installer.
3/8" Butyl ribbon x 15'. Some kits come with the rubber spacer blocks for the bottom edge. Precision's rubber gasket on the windshield.
