cudatom
When I ordered mine it was $6800, I believe the price went up to $7400 at the start of 2019.
Had a 440 in a 10.60 road runner with a little over 300 passes show signs of cap walk but no signs of detonation. Compression was a 11-1 or so.The comment about metal transfer is significant.. and typically points to detonation....
I would definitely call BCR to get their thoughts on the failure
Sorry you are going through this, painful and expensive... Not that there’s any good time for something like this but when you’re in the points it really sucks
LmaoBob you going to use the take forever engine builder again.
I have a license.Will you do a girdle with the good caps? With all that power you could use all the help you can muster untill you find a megablock under the X-mas tree. Me thinks you will need a licence next season!
I think you should send him a new calendar as well.Lmao
It's there already.
He has been warned.
I told him I HAVE to have it back in two weeks.
That should put me at around March 15
From what little I understand , the Indy aluminum block is about $5500, and needs about two more grand to finish machine/ make it right.
But then, I'm not in the market, and may be wrong.
I think Best Machine sells prepped Indy blocks.
How much do the Bullydog bare blocks sell for? I thank my lucky stars I purchased a siamesed block over 20 years ago from Vignogna Peformance in the $2400 range.There’s a hemi being built here....... they’re using a Bulldog block(“The Block”).
Got it a couple weeks ago.
Took 8 weeks from order to delivery.
Bet I could get twice that,but like my pushbuttons that block better outlive me!@HEMI-ITIS , that $2400 inflation adjusts to around $3700 today. Can anybody find a good iron block for that today?
Funny thing, you could probably still get $2400 for that block, and you have had the use of it for twenty years!
What took so long?
