Thoughts on this cam?
Bcamp69
5:24 AM
Indiana
440 stock bore, 452 heads milled .003, cast crank, ly rods, sealed power pistons I think we estimated compression around 9.6:1 or 9.8:1. Edelbrock performer intake, quick fuel 750 carb. Street car that I’m looking to get more out of over the winter.
What are your thoughts on this cam that is currently in it? How much is likely to be gained from a different one? Suggestions?
Honestly I’m not sure what all those numbers mean.
Why such a small follower diameter, or is this a roller diameter? Is that just the recommended minimum diameter, or the diameter used to figure the durations?
Anyhow, 217 duration @ 0.050" is fairly mild in a 440.
What sealed power pistons are they? If you are going by the description, they are probably going to be about 7.5:1.
Universal grind one size fits all master so seat to seat may be large for .050 duration
let's nail down the compression since you said sealed power and not speed pro
stock those heads do not flow more passing say .450 lift
if you do have low compression we can make a big difference one way
if you dohave mid 9:1 we can take a different approach
did you cc the heads or using ??? for data
FSM gives the minimum which is usually way off smaller than reality
stock valves
gears, converter and how heavy a car
what's your view of street?
daily driver or Saturday night street racer
around town stop and go or mostly freeway
headers or stock exhaust duals etc?
can you blow up photo and turn sideways?
And why different sizes?
why different minimum tapped diameter ??? good question
they do not appear to using a dual pattern cam with different masters for intake and exhaust
do we have a brand and part number?
stock magnum was 213-225 @.050 but VERY LONG Ramps, wide lobe centers
I'll try and read that printout
Printout Duration .006 265
lift .471 cam should work fine try it before switching so you know which way to jump and how far
Jones 256-454 (shorter real seat duration for earlier intake close for low comp and more at .200) above is 127@200 which is where the power flow is
some comparisons
Lunati @.006
253 208 454 all the heads flow, no special machining)
256 213 454
Howard 255 208 .479 @.008 so more real duration than lunati above
shorter duration than printout, same lift, should be more @200
would be good choice (or Jones if lower compression
Lunati 262 220 475 about the same duration as printout cam
Howard 265 218 502 more duration than printout cam but looks the same (difference in lift at measurement)
The problem with the Magnum cam is using it with low compression
It runs Hot
the late closing intake bleads off dynamic compression big time
and the late closing exhaust dilutes the intake charge (helps with smog like EGR)
The intake is somewhere around 300 @.004 and exhaust over 310
That’s all the info I have without going to talk to the builder. I’m pretty sure he said it would be 9.6 or 9.8:1. Oh and .020 off the heads, not .003, I was mistaken.
025C0CFE-BAFA-4968-8A19-C20778C3401C.jpeg F1000EB5-8465-4E41-A8F1-81EA040AC4C8.jpeg
Hmmmmmm.
See if you can get the part number.
Can you do a cylinder pressure test?
With a compression gauge? Yeah I can do that. I’ll try to get the part number also. The 452 heads are likely coming off this winter in exchange for the eddy rpms or trick flow 240’s. Are the pistons identifiable from the top?
Maybe
but post your compression test, ignition disconnected- no sparks anywhere and throttle open
and your current cam specs in the same post(make it easy so we do not have to search the thread) and we and perhaps PM AJ/formS
over at https://www.forabodiesonly.com/ and link to this thread
put the trans and gears weight and anything else relevant in the response perhaps aj will run the numbers on the simulator
My newest concern is this block
Maybe
Awesome, I’ll get everything posted up in a week or so.
