jrdriver
New Member
So I’m building my first engine a 77 360 out of an RV for my d250. I know cam choice is a touchy subject but here it goes. The engine is being bored .30 over with 4 relief speed pro pistons my compression should land between 8.5/9:1 depending on head gasket. I’ll be running an edelbrock performer intake with a 600cfm summit carb. The heads will be pretty much stock rebuild maybe some home porting. Truck has a 360 currently hooked to a 727 with 4.10 gears but in the future will be going to 3.55. The truck pretty much lives in the 2-4K rpm range while cruising. It’s just a cruiser but I would like it to be fun to drive. Also converted to HEI. Any good cam recommendations for that low to mid power range? Thanks in advance!
