themechanic
Oklahoma is OK
- 7:49 PM
- Nov 11, 2012
- Moore, Oklahoma
When it comes to seldom used tires the end of life date will always come way before the tread life has ended. For example, I bought four new BFGs in 2013 and maybe put 500 miles on them. I could just inspect the tires and keep them on the car but why wait for a disaster, like one FBBO member shared, where the belt failed, the tire blew and ruined a fender? So, always get tires with a manufacture date as new as possible.
I ordered a set of 4 tires from JEGS (I had store credit); Mickey Thompson Sportsman S/T. Two tires were dated 0119, one was dated 1619 and one was dated 0518. The newest date of 1619 was between April 15-21, 2019, which is just over six months.
JEGS issued a free return via FEDEX. So, I am returning the tires. They ordered a "will call" to check the warehouse for tires made within the last six months.
https://www.tirerack.com/tires/tire...39590&ef_id=XboK5wAABTtFE4NJ:20191106165406:s
When it comes to determining the age of a tire, it is easy to identify when a tire was manufactured by reading its Tire Identification Number (often referred to as the tire's serial number). Unlike vehicle identification numbers (VINs) and the serial numbers used on many other consumer goods (which identify one specific item), Tire Identification Numbers are really batch codes that identify the week and year the tire was produced.
The U.S. Department of Transportation (DOT) National Highway Traffic Safety Administration (NHTSA) requires that Tire Identification Numbers be a combination of the letters DOT, followed by eight to thirteen letters and/or numbers that identify the manufacturing location, tire size and manufacturer's code, along with the week and year the tire was manufactured.
"When it comes to determining the age of a tire, it is easy to identify when a tire was manufactured by reading its Tire Identification Number (often referred to as the tire's serial number)."
Tires Manufactured Since 2000
Since 2000, the week and year the tire was produced has been provided by the last four digits of the Tire Identification Number with the 2 digits being used to identify the week immediately preceding the 2 digits used to identify the year.
Example of a tire manufactured since 2000 with the current Tire Identification Number format:
In the example above:
DOT U2LL LMLR 5107
51
Manufactured during the 51st week of the year
07
Manufactured during 2007
While the entire Tire Identification Number is required to be branded onto one sidewall of every tire, current regulations also require that DOT and the first digits of the Tire Identification Number must also be branded onto the opposite sidewall. Therefore, it is possible to see a Tire Identification Number that appears incomplete and requires looking at the tire's other sidewall to find the entire Tire Identification Number
The use of a partial Tire Identification Number on the one sidewall (shown above) reduces the risk of injury to the mold technician that would have to install the weekly date code on the top sidewall portion of a hot tire mold.
Tires Manufactured Before 2000
The Tire Identification Number for tires produced prior to 2000 was based on the assumption that tires would not be in service for ten years. While they were required to provide the same information as today's tires, the week and year the tire was produced was contained in the last three digits. The 2 digits used to identify the week a tire was manufactured immediately preceded a single digit used to identify the year.
Example of a tire manufactured before 2000 with the earlier Tire Identification Number format:
DOT EJ8J DFM 408
40
Manufactured during the 40th week of the year
8
Manufactured during the 8th year of the decade
While the previous Tire Identification Number format identified that a tire was built in the 8th year of a decade, there was no universal identifier that confirmed which decade (tires produced in the 1990s may have a small triangle following the Tire Identification Number to identify the decade).
And finally, hold on to your sales receipt. Most tire manufacturer's warranties cover their tires for four years from the date of purchase or five years from the week the tires were manufactured. So if you purchase new tires that were manufactured exactly two years ago they will be covered for a total of six years (four years from the date of purchase) as long as you have your receipt. If you lose your receipt, your tires' warranty coverage will end five years from the week the tire was produced (resulting in the tire manufacturer's warranty coverage ending only three years from the date of purchase in this example).
DOT U2LL LMLR 5107
51
07
DOT EJ8J DFM 408
40
8
