- 11:00 PM
- Apr 13, 2012
- Granite Bay CA
Oh yeah...Many topics get off track!
Thanks for the comment. Who was the plant engineer....you? What was your dicipline? If I were your subordinate, I would ask you for your reason for your decision...not to criticize but to learn. Age has nothing to do with the decision. As far as questioning your comment, what is the basis for your comment...it sounds like a "they said rule" or becsuse "I said so" rule. Proclamations without some substantiation as to their validity is just an opinion....and I'm sure you know the saying about opinions.You know Bob, I had a Maintenance Supervisor that questioned everything I did as the plant Engineer back in the '80's while working in the most modern glass bottle plant in North America and he did all he could to discredit my knowledge because I was 20 years his junior .... and when it came down to it he had no idea what his job really was. From this and other previous posts of yours at me it seems you're on the same track for some reason and as I told him, do your own research and maybe you'll keep YOUR job. You type a lot of redirect and never seem to offer any real advise here.
Given the number of vehicles produced since 2000 by GM that will not start with less than 12.8V how can it be that a new battery with less voltage would be acceptable?
Won't either. But them it has to have the ability to crank to start..Won't crank or won't start?
How you make an AGM fit Dennis..
View attachment 862881 View attachment 862882 View attachment 862883
DO NOT trickle charge an AGM. Kill it partially if need be and then hit it pretty hard with 14+ volts to charge at about 8 amps. No need to maintenance charge a good AGM.
Ford telling me that my 2 year old battery in my F150 is good today.. even though within 2 days of charging my auto stop/start won't work because the truck knows it's charging the battery. Tech put it in their fangled tester and it showed 12.23 volts and drew only 379 CCA on it's 760 CCA rating. Charged it and then it tested fine.. even though I've done this twice myself they wouldn't give me a new battery. I booked an appointment for next Friday so they could do it again... lol I have prepaid maintenance and these f'rs are going to learn a lesson or three.
A freshly charged battery should read in the 13.2 / 13.6 range. A good one sitting for a bit at least 12.6
Interesting. It's like over the air digital TV, it's either all there or it's nothing at all.Won't either. But them it has to have the ability to crank to start..
