TwoDogs
In a 1968 Coronet, 440 I have installed (upgraded) to an MSD electronic ignition system. Using wiring diagram that is on page 19 of the instruction booklet, attached. I have an MSD distributor, part number 8546. Cannot get the car to start. Ok, a little back ground, the engine is freshly overhauled and installed, has not ran yet. I know I am getting gas, I know the fuel pump is primed. I have checked spark and am getting it (only checked one plug). I get a nice crank and can hear the compression, but I am getting flames out of the top of the carburetor. I cannot get the engine to start. I have checked to the distributor is not 180 out, its correct. I've also confirmed plug wire to cylinder location *firing order. One thought is to go back to a points ignition to see if I can get it to fire......thank you all for your input.
![IMG_2708[1].JPG IMG_2708[1].JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/796/796904-1568097a86ecae13c27a4ecbd27c2a6f.jpg?hash=FWgJeobsrh)
