- 12:47 PM
- Jan 29, 2018
- Midland Ontario, Canada
Is this an Air Grabber hood.. missing the air box assembly??? or were all RR hoods open this way?? Thanks!
another project wayne?Thanks, .. just thought I should check so I know what else to look for that's probably missing from this 'vert!
At least I have an Air Grabber box..... and a cleaner assembly. Real question is.. is the hood correct to the car!?
There is no reason why it wouldn't be correct........the only exception are the screens......There is NO hole in the firewall for the "carb air" cable...Thanks, .. just thought I should check so I know what else to look for that's probably missing from this 'vert!
Other than simple things to change to make the bay more correct.....It looks nice in the pic you provided...Just a dream at this point, to replace the wife's 'vert I sold on her 2 years ago.
I bet its not black and doesnt have AC with the N96 option...lol....Thanks Richard, something I should have seen right off the bat. What stuck out was seeing sky through the "grills" when I would have thought they'd be shut for a non air grabber unit. I need to go see it... it's a few hours away.
Shouldn't be a big deal. Two screws and the wires are there in the dash harness.i had to change the wiper motor from a two speed to a three speed motor . now i have to install the three speed switch not looking forward to doing that
The big question is ....what condition is it in?Is this an Air Grabber hood.. missing the air box assembly??? or were all RR hoods open this way?? Thanks!View attachment 876228
Do you know the "truth" in it before I go for a day long drive??!!
If not on the FT then NO....LOL Roger.. I know V21's not on the fender tag so the outer black treatment isn't "OE".. as for the hood I'm not versed in '69 Road Runners as to what would have come stock on a Vert. Do you know the "truth" in it before I go for a day long drive??!!
