How to decode Engine Date code stamping?
69 was the only year with the full VIN and not all 69's have the full VIN
Lynch road must have been a crazy place back in the day. Lots of people say that the broadcast sheets were rarely put in lynch road cars, but i found mine in two minutes, the first place i looked. Dadsbees block stamping looks like a three year old did it, and only has 9Axxxxxx, mine is beautifully stamped, also only 9Axxxxxx, yet 4mulas has the full vin on the block and trans, all from the same plant. Im guessing different shifts, different work.
broadcast sheets in cars from the LR plant are not uncommon. Few sheets are found in cars for the LA plant.
full VINs can be found from most plants until sometime in January 1969.
RE C body 383 HP pic from earlier......we need more info. 383 HP was NA in a C body.....yet, if that VIN goes with that pad stamp, more follow up is needed.
I'd say the new paints "muddying" my engine stamp 33, it's actually pretty clear (a shot before I restored the Bee). Feb 25 scheduled car build date, motor wasn't built until Feb 28th! Trans also only stamped with 9A....... and zero Broadcast sheets in my car. I also have this Lynch Rd Road Runner A833, full VIN stamp. Dodge / Plymouth thing or as Coronet has pointed out maybe a date time frame.
My block was cast 12 11 68, stamped December 27 1969, and I have no reason to believe why it wasn’t out Ina fury 4 door as an HP motor. If you ordered it chrysler would make it, also thinking it fits the bill as a cop or fire department car? Who knows, all I know is that it’ll nestle in nicely in my 69 Belvedere, and the date codes are even super close.
You can just see the casting numbers from this pic. Maybe.
I have no idea, just found out about this today myself... I'm happy but disappointed at the same time... This code is on the engine in my 71 Satellite Sebring, which itself came with a 383. I've always thought that it had the original engine still in it, seeing as how this was a base type car factory big block equipped; it was pretty special to me... Hitting me hard that it is a swapped in engine...
Hitting you hard ? Lol !
The existence and location of that number pad indicates a raised block (413,426wedge,440, an rb), therefore it can't be the original in your 383 car. Low blocks have a different pad In a different location. The "E" for 69, assembled in 68, because a middle of November assembly in 69 would be for a 70 model car. A 69 rb would be a 440.
Just above the oilpan rail on the passenger side should be a number with year, assembly plant, and partial vin code of the original car.
Can you identify this block D4 long space 0 then 10 space 282 and sideway A
...identify this block...
Iffy - you should post a pic.
Probably D4 0 is D440 and you just can't see the 2nd "4". D would be model-year 1968 440 cu in
Date is probably Oct 28th (10 28) - the last "2" would mean built 2nd shift
"A" is a 0.020" oversize bore
Thank you identify tried blowing up picture and could not see another 4
