Nacho-RT74
- 11:03 AM
- Oct 8, 2012
- Valencia, España
Have a question...
If stock systems use the ballast having the coil constantly hot from ign switch, and knowing the Ignitor system requires a full 12 volts source... shouldn't the coil still get the resistor hooked up and Ignitor being sourced from a diff + source?
I know Ign III is multispark, kinda the MSD, but MSD sources both leads of coil from its module, so the coil is not constantly hot, but coil on Ignitor III is still hooked up like factory. Even worst on I and II which are not multispark as far I know.
I remember their installing instructions saying bypass the ballast being able to source the ignitor module from + lead of coil, but something sounds out of logic here
