WD-40 cans....What the heck happened?
You don’t need much Kroil at a time, love that stuff. Fluid Film at J.Deere outlets, good also; not so much a penetrant but a great coating.
I'm good with PB and CRC Berkebile products, thanks.
I keep a few cans of PB Blaster on my truck for my chain binders. I can usually get it on sale at AutoZone for around $5.00 a can. No matter how good Kroil is, I can't justify spending $22.00 for a can.
Holy crap..It costs THAT much ???
Am I the only one that uses this stuff. It's the same stuff they use to use for the heat riser valves on the exhaust manifolds until they became obsolete (heat riser valves). Works great but is a little pricey. "I put that @$%# on everything!" lol
Wonder what company makes it for them?
I only buy the WD spray cans. No more aerosol. I also use PB but the WD is better if smell is the issue like in the house.
$21.99 per can. No, my neighbor works at a nearby plant where they buy it by the case. He gave me mine.:lol:
Most garages and shops built prior to 1990 could probably qualify as a Superfund site!!!
Give Kroil a try. They make an aerosol, as well as a liquid in a pint can. Good stuff, I use it a lot where I just want to drip some on the part to be disassembled and an aerosol makes a spray mess.
I used WD40 for years and it was ok.
I recently tried Kroil; used it to loosen up nuts and bolts on my front end rebuild
Even used it to remove the torsion bars.
I was very impressed in how well it works.
Kroil, the "oil that creeps" is my new rust buster.
Ballistol for firearms, right? :)
Castle makes one that is VERY hard to beat....
I use diesel fuel mixed with used trans fluid....I have plenty at my shop its free fra free free....and it works just fine in a hand spry bottle.
